A10SOC uboot dts script bug
BHoey
Hopefully the SOC team monitors this.
The script that is used to create the .h file from the hps_isw_handoff files that is used to generate the pinmux/devicetree for uboot has a bug.
The file is here :
https://github.com/altera-opensource/u-boot-socfpga/blob/socfpga_v2021.07/arch/arm/mach-socfpga/qts-filter-a10.sh
Line 113 ...  _PU_DRV_STRG is 5 bits.  The mask should be 0x1f.
This did create boot issues for us.
Can someone at Intel verify and correct?
-Brian
IntelSupport
Community Manager
Hello BHoey,
We will check your report.
Please wait for a while.
IntelSupport
Community Manager
Hello BHoey,
Thank you for reporting the mask bits problem.
We have confirmed what the mask bit should be 0x1f basd on the configuration register below.
https://www.intel.com/content/www/us/en/programmable/hps/arria-10/hps.html#topic/sfo1429890685214.html
We will update the script in the feture release.
IntelSupport
Community Manager
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
