573 Discussions
Baremetal Example SDMMC makefile failed
CAlex
New Contributor II
CycloneVsoc with BM environment, SOCEDS 20.1 and ARMDS 2021
I downloaded your bare-metal SDMMC sample, but the build failed when using ARMDS make. Here is the error message:
make all
arm-altera-eabi-gcc -g -O0 -Wall -Werror -std=c99 -mcpu=cortex-a9 -mfloat-abi=softfp -mfpu=neon -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -Dsoc_cv_av -c sdmmc_demo.c -o sdmmc_demo.o
process_begin: CreateProcess(NULL, arm-altera-eabi-gcc -g -O0 -Wall -Werror -std=c99 -mcpu=cortex-a9 -mfloat-abi=softfp -mfpu=neon -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -Dsoc_cv_av -c sdmmc_demo.c -o sdmmc_demo.o, ...) failed.
make (e=2)
Before making I've point the SOCEDS_DEST_ROOT to my SOC path.
And I've opened the embedded_command_shell.
Thank you
Alex
alifzakuan_altera
Hi Alex,
May I know where did you obtain the bare-metal SDMMC sample from?
Alif
alifzakuan_altera
Hi Alex,
This also could be because of arm-altera-eabi-gcc compiler is not found in your environment.
Can you help to confirm whether arm-altera-eabi-gcc exists in your PATH?
You could try checking "C:\intelFPGA\20.1\embedded\host_tools\gnu\arm\2019.12\bin" or the likes of it.
Alif
khtan
Hi Alex,
Could you help provide the information that Alif requested, particularly on whether you have the arm-altera-eabi-gcc compiler in your machine?
Kian
khtan
Hi Alex,
May I know what's the status on this issue, whether the issue has been resolved on your end?
Kian
khtan
Hi Alex
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Kian
