I try to run a simple example after installation of DS-5 but it keep fails
07:41:20 **** Build of configuration Default for project Altera-SoCFPGA-HardwareLib-16550-CV-ARMCC ****
make all
armcc -g -O0 --diag_error=warning --diag_suppress=9931 --cpu=Cortex-A9 --no_unaligned_access -IC:/intelFPGA_pro/18.1/embedded/ds-5//../ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA_pro/18.1/embedded/ds-5//../ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -Dsoc_cv_av --strict --c99 -c hwlib.c -o hwlib.o
"hwlib.c", line 40: Error: #5: cannot open source input file "alt_printf.h": No such file or directory
#include <alt_printf.h>
hwlib.c: 0 warnings, 1 error
make: *** [Makefile:89: hwlib.o] Error 1
07:41:21 Build Finished (took 432ms)
- I start a ds-5 shell
- run select_toolchain.bat and select 1 (also tried 2) for arm compiler
- then run in shell eclipse.exe
Building helloworld-baremetal succeeded, but all other armcc examples fails on similar error "cannot open source input file ", although on searching the files they are founded in
C:\intelFPGA\18.1\embedded\ip\altera\hps\altera_hps\hwlib\include
Any idea ?
ranran
- Tags:
- Include
