572 Обсуждение
error when debug an exercise sample application on A10 SOC board
Rainwang
Новый участник II
3 417Просмотр.
hi,
i faced another error.
My PC environment:
virtual box 6.1 + Ubuntu18.04 on windows 10,
Quartus pro 20.1 linux version + SOC EDS pro 20.1 linux version + Arm development studio 2022.0 linux version.
hardware platform: Intel Arria 10 SOC development Kit with a 3 year arm tools license.
The arm ds was activated with the license.
and today, i followed the steps on SoCEDS and ARM Development Studio | Documentation | RocketBoards.org, to exercise the sample application.
after i imported the Altera-SoCFPGA-HardwareLib-Timer-A10-GNU.tar.gz into my workspace and completed the debugger setting as below:
after i click on Debug to start a debugging session, The debugger didn't download the sample application executable on the board, and didn't run it up to the main function.
then i checked the commands window and found below errors
I searched these error on internet but found nothing usful for me. please give me your comments for this, thank you in advance.
0 баллов
1 Решение
Rainwang
Новый участник II
3 119Просмотр.
i found the root cause, the error is caused by the too early exit of uboot spl debugger bufore excecuting the app.
now i understand the app depends on the hardware initialization by the uboot spl.
so after successful running uboot spl, i disconnected the target and run the app examples immediately and it also succeed.
thanks.
Просмотреть решение в исходном сообщении
11 Ответы
AR_A_Intel
Сотрудник
3 398Просмотр.
Hello
Welcome to INTEL forum. To narrow down this issue, can you please provide me the latest of the following?
1) Debug.log file
2) license.dat file
You can also reply/attach your file in private message.
Rainwang
Новый участник II
3 390Просмотр.
Considering the private license information, I had sent you these files via mail. I am not sure if you can get them.
For the debug.log you mentioned, I have not found it in arm directories, so I just copy the information which appeared on the console/commands/target console windows of the arm DS into a file for your reference.
If you told me where to find the debug.log, I will copy it to you then.
thank you!
Rainwang
Новый участник II
3 388Просмотр.
the mail can't be sent out, so i attached the debug file mentioned above for your information. will you pls provide me a private path that i can share my lisense file to you? It seems i can't send you private message here.
thank you.
AR_A_Intel
Сотрудник
3 375Просмотр.
We PM you a private message. Hope you received it.
AR_A_Intel
Сотрудник
3 279Просмотр.
Continue support in private message mail. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
Rainwang
Новый участник II
3 150Просмотр.
who can provide me a update for this issue? thanks!
Rainwang
Новый участник II
3 120Просмотр.
thanks.
Itzthiru
Начинающий
2 654Просмотр.
Hello Rainwang,
               Hope this query finds you well. I am facing the same issue while trying to use Arria 10 SoC for baremetal programming. I am using SOCEDS and ARM DS5. I am trying to execute the sample program that already given with SOCEDS package itself. But i am also getting the same error and can you please let me know how you resolved this issue. Thanks in advance.
Rainwang
Новый участник II
2 612Просмотр.
pls see my solution, you need to run the uboot spl firstly then switch to app, because the app depens on spl to initialize the environment.
Itzthiru
Начинающий
2 602Просмотр.
Can you please let me know in which machine you've tried whether in windows or Linux machine and help me with the below issues also?
When I try to execute bare-metal sample programs for the Arria 10 SoC on Windows using Arm-DS IDE, I encounter the following error message:
Target Message: Memory access caused precise abort. Debug Precise Abort Registers : DFSR = 0x00000817, DFAR = 0xFFFF2000 ERROR(TAD11-NAL18): ! Failed to write 4 bytes to address S:0xFFFF2000 ! Bus error on memory operation
After that from my understanding, I am getting that error because of booloader and I attempted to build the bootloader for Arria 10 SoC in a Linux environment using VirtualBox on my Windows machine. However, during the build process, I am getting the following error:
make socfpga_arria10_defconfig.
makefile:40: *** missing separator. Stop.
Itzthiru
Начинающий
2 369Просмотр.
I have completed the installation and now i am working on the DMA of HPS component. Can you share any example files for toggling HPS LEDS in Arria 10 using direct memory access or i need to configure something before?
Ответить
