Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
About sgx_create_encrypted_enclave
Yurie_F_
Hi!
I'm interested in the enclave the protection of the Enclave itself.
I want to use SGXAPI "sgx_create_encrypted_enclave".
Is there sample code using it or the documentation how to use?
If yes, please let me know.
what encryption algorithm does it encrypt the enclave?
And, can the developer select any algorithm in the future?
Anusha_K_Intel
Loads the encrypted enclave using its file name and initializes it using a launch token.
sgx_create_encrypted_enclave is a macro for the sgx_create_encrypted_enclavea(ANSI) or sgx_create_encrypted_enclavew (Unicode) function.
Syntax:
sgx_status_t sgx_create_encrypted_enclave(
const char *file_name,
const int debug,
sgx_launch_token_t *launch_token,
int *launch_token_updated,
sgx_enclave_id_t *enclave_id,
sgx_misc_attribute_t *misc_attr,
uint8_t* sealed_key
And you can find the information regarding this function is Page No.139 of  https://software.intel.com/sites/default/files/managed/b4/cf/Intel-SGX-SDK-Developer-Reference-for-Windows-OS.pdf
Rodolfo_S_
New Contributor III
Hi, Anusha.
Could you provide more details on how the encrypted enclave is generated? Is there a specific algorithm to be used? What about the key?
I read the Developer Reference, but I couldn't find anything regarding it.
Thank you,
Rodolfo
Yurie_F_
Hi, Anusha, Rodolfo. Thank you for your comments. I have the same question with Rodolfo. I've checked the developer reference, but I want to know the specification in detail about this API. I think the user must encrypt the target enclave at first for using this API. But I don't know how to encrypt it.(e.g. which algorithm, which key) Thanks, Yurie
