Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Build SGX Enclave using Clang/LLVM
Kopf__Benedikt
I was wondering if it is possible to build a SGX enclave using Clang/LLVM instead of GCC. All examples I found use GCC.
Regards, Benedikt Kopf
JesusG_Intel
Hello Benedikt,
It may be possible but Intel has not ported the Intel SGX SDK to Clang. You may encounter some difficulties due to differences between Clang and gcc. You can try out this independent 3rd party Github project, which is not supported by Intel, that is a fork of LLVM with SGX support
Jesus
Kopf__Benedikt
Hello Jesus, thank you very much for your help! Regards, Benedikt
