Is it possible to run SGX enclaves at ring 0?
OR
Can we run SGX enclaves using sudo with root privileges?
I gather that SGX enclaves run at ring 3. Suppose I want to run a program inside SGX enclave which will want to access kernel data structures. Is there any way I could achieve this?
Hi Mazhar,
SGX Enclaves currently only allow for Ring 3 code execution. Intel SGX enclave runs in ring 3 only, no kernel mode.
Intel SGX objective is secure the application in ring 3 itself. Applications are not protected from privileged code attacks. Intel® SGX provides a safe place for code and data in the application.
Thanks and Regards,
Surenthar Selvaraj
Hi Mazhar,
Thanks and Regards,
Surenthar Selvaraj
Surenthar Selvaraj. (Intel) wrote:
Hi Mazhar,
Intel SGX objective is secure the application in ring 3 itself. Applications are not protected from privileged code attacks. Intel® SGX provides a safe place for code and data in the application.Thanks and Regards,
Surenthar Selvaraj
So that means we cannot run a kernel module inside SGX enclaves, right?
Hi Mazhar,
Yes, We cannot run a kernel module inside SGX enclaves.
-Surenthar.
