I am using Intel sgx SDK 2.22 to build an application.
My application triggers by design an ecall multiple times since it is located in a while loop.
After some iterations, the enclave crashes. I used sgx-gdb that gave me this result:
#0 __pthread_kill_implementation (no_tid=0, signo=6,
threadid=140701950515456) at ./nptl/pthread_kill.c:44
44 ./nptl/pthread_kill.c: No such file or directory.
[Current thread is 1 (Thread 0x7ff7b9c79900 (LWP 204777))]
(gdb) bt
#1 __pthread_kill_internal (signo=6,
threadid=140701950515456) at ./nptl/pthread_kill.c:78
#2 __GI___pthread_kill (threadid=140701950515456,
signo=signo@entry=6) at ./nptl/pthread_kill.c:89
#3 0x00007ff7b9642476 in __GI_raise (sig=sig@entry=6)
at ../sysdeps/posix/raise.c:26
#4 0x00007ff7b96287f3 in __GI_abort ()
at ./stdlib/abort.c:79
#5 0x0000561457587796 in add_lost_keys_in_enclave (
local_lost_keys_set=std::set with 1 element = {...})
at App/TrustedLibrary/Types.cpp:139This is the code of the add_lost_keys_in_enclave() function (which is called inside a while loop) where it systematically abort after some normal executions :
void add_lost_keys_in_enclave(const set<string>& local_lost_keys_set){
string lost_keys_string="";
for (const auto& key_with_last_share_owner : local_lost_keys_set) {
lost_keys_string += key_with_last_share_owner+"\n";
sgx_status_t ret = SGX_ERROR_UNEXPECTED;
ret = ecall_add_lost_keys(global_eid, convertCString(lost_keys_string));
if (ret != SGX_SUCCESS)
abort();
}What can I do ?
Hi Aghia,
We are checking on this with engineering team and will get back to you once the information available. Thanks for your patience.
Aznie
Hi Aghia,
We have provided updates in your previous post on this Community. Therefore, I will close this ticket and we will continue providing support on your post below:
Aznie
