Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Do E-2356G and E-2386G have EPID support?
ArminD
Hello again,
in this thread the following was written:
The Xeon E-series 2200 and 2300 processors support FLC/DCAP and EPID.
We are currently interested in E-2356G and E-2386G processors. We have an SGX application which uses EPID attestation and which already runs nicely on e.g. an i5-6300U or E3-1225 v5. I want to be sure, could you please confirm whether this application in general can run without modifications on the E-2356G or E-2386G, especially under the aspect that the existing EPID attestation code should work as-is on the newer processors?
In addition, do I understand it correctly that I need to also talk to the motherboard vendor whether the E-2356G or E-2386G SGX EPID functionality works with their motherboard?
Thank you!
Sahira_Intel
Hi Armin,
I apologize for my late reply.
Yes, he E-2300 series processers should support EPID. The motherboard BIOS must also support SGX, so you could contact the vendor to confirm that SGX is supported on certain motherboards.
I hope this information is helpful
Sincerely,
Sahira
Sahira_Intel
Hi Armin,
Sincerely,
Sahira
