Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
How expensive is an AEX?
Urs_M_
Hey guys,
I am wondering how expensive an asynchronous exit is compared to a normal context switch.
If I understand the documentation correctly, the enclave stores the CPU's registers to the sate save area (SSA). Due to some alignment requirements, the SSA should usually be the size of a single page (4096 bytes).
Intel SGX, however, allows larger SSAs (specified by SSAFRAMESIZE). What else is or can be stored in an SSA? If SSAFRAMESIZE can get large, an AEX might be rather expensive. How big is SSAFRAMESIZE usually?
Best, Urs
Francisco_C_Intel
https://github.com/01org/linux-sgx/blob/57cb162f126397facf049f4f0fbd293d56dd2e63/sdk/sign_tool/SignTool/manage_metadata.h
has
#define SSA_NUM 2
#define SSA_FRAME_SIZE 1
And
https://github.com/01org/linux-sgx/blob/57cb162f126397facf049f4f0fbd293d56dd2e63/common/inc/internal/metadata.h
has the following defined:
#define SSA_NUM_MIN 2
#define SSA_FRAME_SIZE_MIN 1
#define SSA_FRAME_SIZE_MAX 2
It appears the software is using 1 page for each SSA, two SSAs per TCS.
Francisco_C_Intel
has
#define SSA_NUM 2
And
Urs_M_
Awesome, thank you very much!
