Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Intel SGX Data encryption
sunho__choi
I want to perform an operation inside an enclave and encrypt it when passing the computed value to the outside.
How do I encrypt my data?
-Thank you
Rodolfo_S_
New Contributor III
Hi there,
You can find an example on how to encrypt data inside enclaves in this github project.
Rodolfo
Junli_S_Intel
You can also refer the Intel SDK's sample code: SealUnseal. You can find this source code in the SDK installer, or you can find in the github: https://github.com/intel/linux-sgx/tree/master/SampleCode/SealUnseal
Rodolfo_S_
New Contributor III
It is important to mention that the unsealing of data can only be performed in the same machine where the seal operation has occurred, and also that the user **cannot** choose a specific key to use to encrypt/decrypt data.
[]s
Rodolfo
