Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Intel SGX
ee_b_
I'm trying to create a basic sgx via visual studio 2015 on my windows 10 computer.
However, every time I call sgx_create_enclave the metadata is invalid and it returns with the status SGX_ERROR_INVALID_METADATA (0X2009).
From what I understand this means the Enclave.signed.dll is corrupt, but I don't understand how I can fix it.
Thanks in advance
Prabu_R_Intel
I checked the uploaded Intel SGX sample application(simulation mode) source.
1) In simulation mode, the application and enclave configurations should point "Local Windows Debugger" .
2) Moreover I found that below said path in enclave project setting is pointing to "$ProjectDir" instead of "$OutDir"
"Configuration Properties --> Debugging --> Working Directory"
Please make sure that the latest Intel SGX SDK(1.7) is used with Visual Studio 2015 and Windows 10.
R.Prabu
ee_b_
Thanks, I did those corrections, however it is giving me the same problem
Marcos_Vinicius_Mont
The document Software Guard Extensions programming Reference  is written "extensions allow an application to instantiate a protected container, referred to as an enclave. An enclave is a protected area in the application’s address space (see Figure 1-1), which provides confidentiality and integrity even in the presence of privileged malware "
However, figure 1 does not reflect what is written in the text above. What really happens with the enclave? It sits within the memory space of the application, or it sits in a separate memory space of the application in main memory?sgxx_0.jpg
