Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Is there any way to use fenv.h?
dai_c_
Hello,When I put some code in Enclave,I want to use some function of fenv.h,but It seems not support this,so Is there any way to use fenv.h in Enclave,Thank you very much!
Hoang_N_Intel
This header is clearly documented in the "Unsupported C Standard Functions" section in the SGX Developer Reference at https://download.01.org/intel-sgx/linux-1.9/docs/Intel_SGX_SDK_Developer_Reference_Linux_1.9_Open_Source.pdf
Please refer to page 312 for more details.
dai_c_
OK,Thank you very much. and Is there any way to use fenv.h which Enclave not support?
