Community
cancel
Showing results for
Search instead for
Did you mean:
Meysam_t_
Maximum size of the buffer allocated inside the Enclave
Dear All,
What is the maximum size of a buffer that we can allocate inside the enclave?
I mean if I am defining a function in my enclave.edl as follows
public void buffer_block_access([out, size=block_length]char*buffer, size_t block_length);
what is the maximum of "block_length" that I can define?
I malloc a buffer with the size of 2MB in my code like this
const size_t SZ = 2097152;
char *buff = (char *)malloc(SZ*sizeof(char));
and when I call the function as mentioned bellow
 sgx_status_t stat = buffer_block_access(global_eid, buff, SZ);
It returns back
stat = 3
Tags (1)
Junli_S_Intel
It will depends on two factors:
1. Your system's EPC size: you can modify and configure your EPC size in your system's BIOS
2. your enclave's configuration file(enclavename.config.xml):  this is one typical enclave configuration file:
<EnclaveConfiguration>
  <ProdID>0</ProdID>
  <ISVSVN>0</ISVSVN>
  <StackMaxSize>0x40000</StackMaxSize>
  <HeapMaxSize>0x100000</HeapMaxSize>
  <TCSNum>1</TCSNum>
  <TCSPolicy>1</TCSPolicy>
  <DisableDebug>0</DisableDebug>
  <MiscSelect>0</MiscSelect>
  <MiscMask>0xFFFFFFFF</MiscMask>
</EnclaveConfiguration>
Please pay attention to the high-light part.
