While trying to install mei-7.1.20-25, I encounter the error :
make -C /lib/modules/`uname -r`/build M=`pwd` modules
make[1]: Entering directory '/usr/src/linux-headers-4.13.0-36-generic'
CC/home/sushant/Downloads/outputdir/mei-7.1.20/src/init.o
In file included from /home/sushant/Downloads/outputdir/mei-7.1.20/src/init.c:20:0:
/home/sushant/Downloads/outputdir/mei-7.1.20/src/init.c:33:6: error: expected ‘,’ or ‘;’ before ‘__MODULE_STRING’
__MODULE_STRING(AMT_WD_VALUE)
./include/linux/moduleparam.h:23:26: note: in definition of macro ‘__MODULE_INFO’
= __stringify(tag) "=" info
/home/sushant/Downloads/outputdir/mei-7.1.20/src/init.c:31:1: note: in expansion of macro ‘MODULE_PARM_DESC’
MODULE_PARM_DESC(watchdog_timeout,
/home/sushant/Downloads/outputdir/mei-7.1.20/src/init.c: In function ‘mei_hw_init’:
/home/sushant/Downloads/outputdir/mei-7.1.20/src/init.c:234:38: warning: comparison of constant ‘8’ with boolean expression is always true [-Wbool-compare]
if (!(dev->host_hw_state & H_RDY) != H_RDY)
/home/sushant/Downloads/outputdir/mei-7.1.20/src/init.c:234:38: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]
/home/sushant/Downloads/outputdir/mei-7.1.20/src/init.c:237:41: warning: comparison of constant ‘8’ with boolean expression is always true [-Wbool-compare]
if (!(dev->me_hw_state & ME_RDY_HRA) != ME_RDY_HRA)
/home/sushant/Downloads/outputdir/mei-7.1.20/src/init.c:237:41: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]
scripts/Makefile.build:308: recipe for target '/home/sushant/Downloads/outputdir/mei-7.1.20/src/init.o' failed
make[2]: *** [/home/sushant/Downloads/outputdir/mei-7.1.20/src/init.o] Error 1
Makefile:1550: recipe for target '_module_/home/sushant/Downloads/outputdir/mei-7.1.20/src' failed
make[1]: *** [_module_/home/sushant/Downloads/outputdir/mei-7.1.20/src] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.13.0-36-generic'
Makefile:27: recipe for target 'all' failed
make: *** [all] Error 2
Note: By mistake, I had installed the psw with only the tools installed
(command: $ sudo apt-get install libssl-dev libcurl4-openssl-dev libprotobuf-dev)
and not following other prerequisites.
How should I resolve the error?
