Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Null return values from [out] variables from enclave.
MoonHasSevenColor
Hello, I imitage the code of intel introduction to pass parameters between enclave and app , to make test for out parameters between app and enclave, but the returned [out] value from enclave is null, which has been changed at enclave.
The out parameter is defind as:
I attach the code. You can "make" at the root directory, and then "./app" to execute. Thank you for your help!
Wan_Intel
Hello MoonHasSevenColor,
I encountered the same result as you when running your application.
Let me check with the relevant team and I'll update you as soon as possible.
Wan
MoonHasSevenColor
Dear Wan,
Thank you for your help and Look forward to your replying!
Jin Xin
Wan_Intel
Thanks for your patience. We've received feedback from relevant team.
For your information, the tutorial that you are referring to: Intel® SGX Intro: Passing Data Between App and Enclave is outdated.
We suggest you to check out the Sample Codes in Intel® SGX SDK, where a few samples may help with understanding how Enclaves work and communication between trusted and untrusted applications work.
Hope it helps.
Wan
Wan_Intel
Thanks for your question.
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
