Dear Intel SGX Team,
I have a question about the proper usage of SDK function, sgx_rijndael128GCM_encrypt. In the "Intel SGX Developer Reference Guide", there is a description for the function. It says that "It is recommended that the source and destination data buffers are allocated within the enclave". However, what I wonder is that do we need to allocate the destination buffers within the enclave? I think the destination buffer only contains the encrypted data, so it can be allocated outside the enclave memory.
If we can allocate the destination buffer outside the enclave memory, I can use [user_check] for the function in the EDL file. (When I tested the latency difference between [out] and [user_check], it was not a big deal, but the [user_check] was a little bit better)
So, I wanna know why allocating destination buffer within the enclave is recommended. (I'm not sure but is it related to security issues?)
I really appreciate any comments.
Thank you in advance.
David Cho.
Hello David,
It is recommended that the destination be inside the memory space of the enclave in order to not place enclave data into untrusted/unprotected memory space. You are right, the data is encrypted (this is why it's a recommendation rather than a requirement), and you will get better performance using [user check] because with [user check] the compiler does not create the proxy functions to marshal the data across the trust boundaries.
I recommend to read this article for more details on data marshaling: https://software.intel.com/content/www/us/en/develop/articles/intel-software-guard-extensions-tutorial-part-7-refining-the-enclave.html
Hello David,
We are looking into your issue. Please stay tuned.
Hello David,
Thanks for your kind reply.
It helps me a lot.
Have a good day!
David Cho.
