Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Question on SGX BIOS Switches
Sam5
What are the support BIOS switches for SGX? What does Application Enabled mean?
-Thanks
Surenthar_S_Intel
Hi Sam,
BIOS switches for SGX:
Enabled, Disabled, and Software Controlled (or Application Enabled, or some other wording that is similar).
  • Enabled means it is on.
  • Disabled means it is off.
  • Software Controlled means that an SGX application will flip the bit to enabled the first time one runs. It uses the Platform Software to do this (PSW)
The reason for the software controlled state is because SGX does consume up to 128 MB of RAM (on current platforms) for the processor reserve memory, about 90 MB of which is used for the enclave page cache. OEM's prefer not to have these resources consumed by default if there are no SGX applications installed on the system.
Thanks and Regards,
Surenthar Selvaraj
Surenthar_S_Intel
Hi Sam,
Thanks and Regards,
Surenthar Selvaraj
Sam5
Thanks for your detailed info...
