Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Repost - Please update the Intel SGX VM document
Anandakumar
New Contributor II
I am posting this again because no updates for past 20 days.
https://community.intel.com/t5/Intel-Software-Guard-Extensions/Please-update-the-Intel-SGX-VM-document/m-p/1340504#M5021
https://www.intel.com/content/www/us/en/developer/articles/technical/virtualizing-intel-software-gua...
The above document has steps to install QEMU from https://github.com/intel/qemu-sgx.
Now the official QEMU repo has included the intel SGX changes from version 6.1.50 it seems.
There are few differences in VM flags and configuration in new versions.
ex: -sgx-epc flag is not supported in the new version.
So please do update the documentation with proper vm xml configurations for new QEMU version.
Anandakumar
New Contributor II
Anandakumar
New Contributor II
Hello All,
Linux version 5.14.9-custom
QEMU emulator version 6.2.0 (v6.2.0)
I am able to start a testvm using following commandline,
`sudo qemu-system-x86_64 -nographic -enable-kvm -cpu host,+sgx -object memory-backend-epc,id=mem1,size=8M,prealloc=on -object mem0.memdev
But when I try the same with libvirt, I am getting this,
`error: internal error: unable to execute QEMU command 'qom-get': Property 'sgx-epc.unavailable-features' not found
testvm.xml content:
`<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
<name>test</name>
<uuid>3d5bba5b-0b5b-4b2b-a425-171fe9b31140</uuid>
<memory unit='KiB'>4194304</memory>
<currentMemory unit='KiB'>4194304</currentMemory>
<vcpu placement='static'>1</vcpu>
<os>
<type arch='x86_64' machine='pc-i440fx-6.2'>hvm</type>
<loader readonly='yes' type='pflash'>/usr/share/OVMF/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/testvm_VARS.fd</nvram>
<boot dev='hd'/>
</os>
<features>
<acpi/>
<apic/>
<pae/>
</features>
<cpu mode='custom' match='exact' check='none'>
<model fallback='forbid'>qemu64</model>
</cpu>
<clock offset='utc'/>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>restart</on_crash>
<devices>
<emulator>/usr/local/bin/qemu-system-x86_64</emulator>
<disk type='file' device='disk'>
<driver name='qemu' type='qcow2' cache='none' io='threads'/>
<source file='/home/sas/testvm.qcow2'/>
<target dev='vda' bus='virtio'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0'/>
</disk>
<controller type='ide' index='0'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/>
</controller>
<controller type='usb' index='0' model='piix3-uhci'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
</controller>
<controller type='pci' index='0' model='pci-root'/>
<input type='mouse' bus='ps2'/>
<input type='keyboard' bus='ps2'/>
<memballoon model='virtio'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/>
</memballoon>
</devices>
<qemu:commandline>
<qemu:arg value='-cpu'/>
<qemu:arg value='host,+sgx,+sgxlc'/>
<qemu:arg value='-object'/>
<qemu:arg value='memory-backend-epc,id=mem1,size=8M,prealloc=on'/>
<qemu:arg value='-machine'/>
<qemu:arg value='sgx-epc.0.memdev=mem1'/>
</qemu:commandline>
</domain>
SGX virtualization document not updated for the latest qemu version. https://www.intel.com/content/www/us/en/developer/articles/technical/virtualizing-intel-software-guard-extensions-with-kvm-and-qemu.html
ChrisB_Intel
Thanks for your inquiry. I will pass it along to engineering, however, due to the holidays we will probably not get back to you until early January.
Anandakumar
New Contributor II
