Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Running AMX instructions inside SGX Enclave
jk123
I am trying to execute an AMX instruction inside an SGX enclave. I am using RHEL 9.3. I have confirmed that I can run an AMX instruction outside of an enclave, but not inside it when initializing AMX outside of the enclave. Executing the enclaved code returns error code 0x1006. I can't reinitialize AMX inside the enclave because it requires a system call, and system calls are impossible inside an SGX enclave. Is there any way to run AMX inside an enclave? I have attached a minimal reproducible example.
It is based off the code here and here
Scott_R_Intel
Hello.
Please see our latest SGX Developer Reference.  It talks about how to enable AMX in an enclave.
Regards.
Scott_R_Intel
Hello.
Regards.
