Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX-Driver builds with errors in WSL
aaaaaalife
I am running ubuntu 20.04 on WSL and trying to run a project on SGX, but when I install SGX-Driver-1.4.1 I get the error "failed to build driver"
KFPW_Intel
We found out that SGX is not enabled in WSL at all. Therefore, it is not possible to compile/ load it in WSL.
Like a hypervisor or VMM, SGX would have to be passed through as a feature to WSL.
Confirm that SGX is not enabled by running:
sudo cpuid | grep -i sgx
You should see everything come back as false, including SGX: Software Guard Extensions supported = false.
Let us know if you have any questions regards to this issue.
Thank you.
Ken
KFPW_Intel
Thank you for your interest in Intel® SGX.
Please check if the platform supports SGX/FLC. We have an article that may be useful for your use cases.
Based on the article, we suggest these steps to test on your platform.
On a Linux* system, execute cpuid in a terminal:
Open a terminal and run: $ cpuid | grep -i sgx
Look for output: SGX_LC: SGX launch config supported = true
Hope that the information provided is useful. Let us know if you have any questions regards to this issue.
Thank you.
Ken
KFPW_Intel
Thank you.
Ken
KFPW_Intel
I hope the information I provided was helpful to you. Do you need further help with this issue?
Please inform us if you have any questions regards to this issue.
Thank you.
Ken
KFPW_Intel
I hope the information I provided was helpful to you. Since we haven't heard from you, Intel will stop monitoring this thread. If you need further assistance, please open a new thread.
Ken
