Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
SGX Internal CREGs
gu_j_1
How to get the value of SGX Internal CREGs?
When enclave A makes a report to enclave B, in enclave B I want to get the same report key which is used during enclave making the report.
So, it seems that I must know some CREGs' value such as CR_SEAL_FUSES.
Surenthar_S_Intel
Hi Gu,
There is an SDK API, sgx_verify_report(report), to perform this function.  An enclave can also generate the report key using the API, sgx_get_key(key_request, &key), which is a wrapper for SGX's EGETKEY instruction.  The report's MAC is generated using AES128_CMAC.
CREG's are internal registers to the part. The programmer is not supposed to have access to them.
Thanks and Regards,
Surenthar Selvaraj
Surenthar_S_Intel
Hi Gu,
Thanks and Regards,
Surenthar Selvaraj
