Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SGX Memory Management
Kumar__Dixit
In SGX, after setting up the elrange in Enclave Creation Phase, do the SGX copy all pages from non-epc region to epc-region (belongs to the elrange)?  Or do they copy the elrange pages only dynamically, as per demand paging?
JesusG_Intel
Hello Dixit,
The pages are copied dynamically as needed. Note that paging is handled by system software, not by SGX. You can find more info in these slides, which I highly recommend reading, and this whitepaper. The Intel SGX Life Cycle blog and PDFs at the bottom are also quite useful if you want to get a better understanding.
Jesus
Intel Customer Support
