Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
SSE instruction in enclave
hyunsoo
Are SSE instructions possible in enclave? (such as _mm_set1_ps, _mm_add_ps, etc)
Thank you.
JesusG_Intel
Hello Hyunsoo,
Yes, it is possible to use SSE instructions from within enclaves but you will have to manually copy the relevant header files to your enclave's include directory. For example, Step 3 in the Eigen in Intel SGX Github states:
"Locate the following files in system directories and copy them over to Include/intrinsic. Usually, they are located in gcc's include directory (e.g. /usr/lib/gcc/x86_64-linux-gnu/6.5.0/include).
  • emmintrin.h
  • mmintrin.h
  • mm_malloc.h
  • xmmintrin.h"
You will have to do the same if using Windows.
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello Hyunsoo,
  • emmintrin.h
  • mmintrin.h
  • mm_malloc.h
  • xmmintrin.h"
Sincerely,
Jesus G.
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
