Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
Security issues regarding calling untrusted functions in non secure areas
dongconse
  In the enclave, only trusted functions from the trusted library can be called. However, if there are necessary operations that cannot be provided by the trusted library, I must call the Ocall function to execute them in the non secure area.
  Is there a risk of leakage for the parameters I pass to the Ocall function?
  What measures can I take to improve its security?
dongconse
  If I want to call OpenCV library functions to obtain images, but the OpenCV library is an untrusted library, I need to call the Ocall function to run the OpenCV library functions in the untrusted area. In addition, the obtained files also belong to image format files. How do I protect them?
