Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Some Link Error when using sgx_create_report
Rong_Z_
I'm trying to use sgx_create_report() to create the report for enclave, but it always fails during the build process, showing that some link errors like below:
Error    2    error LNK2019: unresolved external symbol _sgx_is_within_enclave referenced in function _sgx_create_report    C:\Users\Administrator\Documents\Visual Studio 2012\Projects\Enclave\App\sgx_tservice.lib(sgx_create_report.obj)
Error    3    error LNK2019: unresolved external symbol _do_ereport referenced in function _sgx_create_report    C:\Users\Administrator\Documents\Visual Studio 2012\Projects\Enclave\App\sgx_tservice.lib(sgx_create_report.obj)
Error    4    error LNK2019: unresolved external symbol _memset_s referenced in function _sgx_create_report    C:\Users\Administrator\Documents\Visual Studio 2012\Projects\Enclave\App\sgx_tservice.lib(sgx_create_report.obj)
Error    5    error LNK1120: 3 unresolved externals    C:\Users\Administrator\Documents\Visual Studio 2012\Projects\Enclave\Debug\App.exe
It seems that some library been missed, does anyone have the same problem? And Does anyone have some sample codes which can successfully calling sgx_create_report? Could you please share some sample code with me?
Rong
Surenthar_S_Intel
Hi Rong,
Could you please share the code, will verify and get back.
Thanks and Regrads,
Surenthar Selvaraj
