The program running in an enclave based on Intel SGX—the process of data intersection between parties A and B—does it have a solution where data can be output in plaintext to the log? Based on the ccoo case, the cross_lang_framework case, the data running in the program can be output in plaintext to the console. In this way, if the SGX environment is on A's machine, can A output the data obtained from B outside the enclave?
