Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
Unable to run SGX LocalAttestation example in Simulator on Linux cloud instance (AWS)
Cipolla__Henry
Even though Amazon's instances don't support SGX, I am trying to get a simulation environment working to play with. The SampleEnclave example works fine but LocalAttestation example keeps returning 2002. This should work given everything is run in software, right?
LocalAttestation$ make clean ; make SGX_MODE=SIM ; ./app
But the output I get is:
The project has been built in debug simulation mode.
Load Enclave Failure
Available Enclaves
Enclave1 - EnclaveID 0
Enclave2 - EnclaveID 0
Enclave3 - EnclaveID 0Enclave1_test_create_session Ecall failed: Error code is 2002
Hit a key....
Am I missing something obvious and silly?
Cipolla__Henry
Adding some debugging information to the example, the error I'm getting is 0x3002 "The enclave is not authorized." Again, I would have thought this doesn't happen when you use the simulator. Is there a requirement I'm missing?
