Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
installing SGX driver for ubuntu.
Shredha_K_
I got this error when I tried to install the SGX driver for ubuntu 14.04.  modprobe: ERROR: could not insert 'isgx': Required key not available.
 I followed the installation guide on the official site https://download.01.org/intel-sgx/linux-1.7/docs/Intel_SGX_SDK_Installation_Guide_Linux_1.7_Open_Source.pdf:
How can I solve this.
Thanks in advance.
Surenthar_S_Intel
You may want to disable secure boot in BIOS settings and enable SGX .
Under “Security” Tab,
   i. Under “Intel® SGX”
       1. Set Intel ® SGX Control to “Enabled”
   ii. Under “Secure Boot”
       1. Set Secure Boot to “Disabled”
-Surenthar
Saeid_M_
Hi Shredha,
I got the same error when I tried to install Linux kernel driver on my Ubuntu OS which was on a VM-Ware virtual machine and with a None-SGX enabled computer. Then, I tried it again with My SGX-enabled machine and a real Linux(Not VM), and everything was ok. Based on my observation I would conclude that either your CPU is not SGX enabled CPU or you did not enable SGX functionality in your computer BIOS.
Possible solutions:
1-Make sure you have a Skylake CPU which is 6th generation CPU.
2-Make sure you have enabled SGX support functionality in your computer BIOS.
Saeid
Surenthar_S_Intel
-Surenthar
Shredha_K_
Thank you for the comments. It really helped
Garg__Shivam
facing the below issue when installing the SGX driver on Centos 7.4.
[root@local_host POC1]# sudo ./sgx_linux_x64_driver_1.6.100.32783.bin
Unpacking Intel SGX Driver ... done.
Verifying the integrity of the install package ... done.
Installing Intel SGX Driver ...
/tmp/sgx-driver-AjAGqc ~/POC1
install -d /opt/intel/sgxdriver/package
install -d /opt/intel/sgxdriver/scripts
install package/* /opt/intel/sgxdriver/package
install scripts/* /opt/intel/sgxdriver/scripts
~/POC1
/opt/intel/sgxdriver/package ~/POC1
make -C /lib/modules/3.10.0-327.36.1.el7.x86_64/build SUBDIRS=/opt/intel/sgxdriver/package CFLAGS_MODULE="-DDEBUG -g -O0" modules
make: *** /lib/modules/3.10.0-327.36.1.el7.x86_64/build: No such file or directory.  Stop.
make: *** [default] Error 2
/bin/sed: can't read /etc/modules: No such file or directory
