Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
sgx-ra-sample make failed
mzaman
I was trying make sgx-ra-sample on a ubuntu docker container. But its failed with ld exit status. I just trying to run the server. Here is the screenshot:
Screenshot from 2021-02-18 17-17-00.pngScreenshot from 2021-02-18 17-17-00.png
Could you please me what I am doing wrong?
Mzaman
JesusG_Intel
Hello mzaman,
I am not an expert on Docker, and the sample was meant to be installed and run natively, so my support will be limited but I'll do the best I can.
  1. Did you install OpenSSL 1.1.0 or 1.1.1? Execute: openssl version. Ensure you have installed OpenSSL 1.1.1. The instructions say OpenSSL 1.1.0 but other customers and I have had better luck with OpenSSL 1.1.1.
  2. Set the correct path to your OpenSSL include directory here, which may differ from what is written:
$ ./bootstrap
$ ./configure --with-openssldir=/opt/openssl/1.1.0i <--Change this path to match your OpenSSL 1.1.1 directory
$ make
3. Do any of the other SGX SDK samples work in your Docker image?
Sincerely,
Jesus G.
Intel Customer Support
JesusG_Intel
Hello mzaman,
$ ./bootstrap
$ make
Sincerely,
Jesus G.
JesusG_Intel
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
