OS : x86_64 GNU/Linux (CentOS 6.4)
Compiler : Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.1.1.163 Build 20130313
Debugger : Version 13.0
FFLAGS : -debug -cpp -zero -convert big_endian -traceback -fpe0 -g -debug extended -assume byterecl -i4 -132 -fp-stack-check -complex-limited-range -check bounds,pointers,uninit -ftrapuv
I have numerous cases when a routine is called with an array with explicit declaration of the array size, but the called routine reports different size. Here is an example:
subroutine get_c4(c4,num_px,sol)
implicit none
type(tet_t),intent(in) :: c4
integer,intent(in) :: num_px
double complex,intent(in) :: e_sol(num_px)
get_c4 is called with num_px=8585 and with a double coplex x(1:8585), but get_c4 reports 340:
(*** from inside get_c4 ***)
(idb) p num_px
$49 = 8585
(idb) whatis e_sol
type = COMPLEX(16) (340)
Is it a bug? Do I miss something?
Thanks in advance,
--Ted
