Community
cancel
Showing results for
Search instead for
Did you mean:
Dmitry_O_Intel
Build problem C1000 hello world win server 2008
Good day
Installed the latest version of the studio. (Build: issm_q2_2016_32_2016-07-26-0-g9e73b2ad5b)
Tried to build hello world and got next error. (Skip ROM flashing step if it's necessary)
make
APP_NAME = Hello_World
SOC = quark_se
TARGET = x86
APP_DIR = .
BUILD = debug
CSTD = c99
VERSION = '1.1.0'
make -C ./bsp/drivers SOC=quark_se TARGET=x86 BUILD=debug V=0 CSTD=c99
BUILD = debug
CSTD = c99
VERSION = '1.1.0'
make[1]: Entering directory `C:/Users/domelchx/microcont_ws/Hello_World/bsp/drivers'
The syntax of the command is incorrect.
"CC ../drivers/debug/quark_se/x86/obj/clk.o"
Assembler messages:
Fatal error: can't create ../drivers/debug/quark_se/x86/obj/clk.o: No such file or directory
make[1]: *** [../drivers/debug/quark_se/x86/obj/clk.o] Error 1
make[1]: Leaving directory `C:/Users/domelchx/microcont_ws/Hello_World/bsp/drivers'
make: *** [libqmsi] Error 2
16:18:58 Build Finished (took 702ms)
I use win server 2008.
C:\Users\domelchx\ws_tst_atp>wmic os get name
Name
Microsoft Windows Server 2008 R2 Enterprise |C:\WINDOWS|\Device\Harddisk0\Partit
ion1
to fix build I quoted the Microsoft Windows Server string in the bsp/base.mk
- ifneq (,$(findstring Microsoft Windows Server, $(OSNAME)))
+ ifneq (,$(findstring "Microsoft Windows Server", $(OSNAME)))
Dmitry.
Alice_H_Intel
Hi Dmitry,
Thank you for your question. For the ISSM, we support following OS.
  • Linux (64bit: Ubuntu* 14.04 LTS and Fedora* 21)
  • Windows* (64bit: Versions 7, 8.1, and 10)
Can you find a proper machine to install ISSM and try to build the project again ?
Hope this can help you.
Alice
Dmitry_O_Intel
Hi Alice H,
I could use current machine(mststcxw25) with changed bsp/base.mk file.
I could use the same machine with older ISSM version without modifications of the bsp/base.mk file.
Looks like a bug.
Dmitry.
Alice_H_Intel
Hi Dmitry,
Sorry I didn't catch your questoin. As you mentioned, the build issue is sloved by bsp/base.mk file modification ?
please provide more information.
Alice
Dmitry_O_Intel
Set the Microsoft Windows Server string in quotes help me. But I believe the problem is with usage of the md utility(for server version the mkdir utility is used).
Dmitry.
John_B_Intel
Hi Dmitry,
Did you manage to resolve the error: "CC ../drivers/debug/quark_se/x86/obj/clk.o"  ?
I am having the same issue.
John
Dmitry_O_Intel
Hi John,
I resolved this error for my case windows server 2008 os. Looks the makefile's commands fail to create debug/quark_se/x86 directories.
You could try to create them by yourself but this is very annoying process.
Dmitry.
