Community
cancel
Showing results for
Search instead for
Did you mean:
crobot_2000
CE4100 18.26903 SDK build error
I just installed the SDK, and when I do "make menuconfig" I got compilation error in lxdialog/dialog.h : curses.h No such file or directory.
Little poking around and figured out the build process requires ncurses-5.6, which is still tarred under package/devtools.
My expectation was it should be untarred automatically when I am doing a first time build. I tries deconfig it did not work.
Any suggestions on how to get past this?
Thanks!!
Robert_M_Intel1
Dear customer,
ther Intel Embedded Software Development Tool Suite does not cover the CE Linux build environment for Intel Atom Processor CE4xxx istelf.
I will go ahead ane escalate this question of yours and get it put into the right channel.
Thanks, Rob
