Community
cancel
Showing results for
Search instead for
Did you mean:
jschi71
Cannot Debug target-select remote 127.0.0.1:3333
Hi Yesterday I could debug with the Intel System Studio for Microcontrollers, I am working on a D2000. The IDE is running on a Windows 7 machine. Today when I try to load a program (accel) it gives me the following error message: Error in final launch sequence Failed to execute MI command arget-select remote 127.0.0.1:3333
Error message from debugger back end: 127.0.0.1:3333: The system tried to join a drive to a directory on a joined drive. 127.0.0.1:3333: The system tried to join a drive to a directory on a joined drive. What can I do to fix this ? Thanks for the help --jim schimpf
jschi71
Fixed !! Reset the computer running the Studio and now it works.
Richard_A_Intel
Jim,
Glad you were able to fix this issue.  That error can have several causes but in short it means the tools are not detecting your board.  This can be caused by a missing driver, board not connected, or a crashed OpenOCD session.
Thank you,
Richard
