Community
cancel
Showing results for
Search instead for
Did you mean:
Anonymous
Not applicable
Cannot install on Mac, Windows 10 or Linux
Jump to solution
Is there any way around getting this (IoT Versions https://software.intel.com/en-us/installing-the-intel-system-studio-iot-edition) installed on Mac, WIndows or Linux, my version of Mac is not supported. 10.12 and Windows continually gives error of:
Intel® System Studio IoT Edition Setup Wizard ended prematurely because of an error(s).
Can't create/start docker machine: no progress report file was found
I later got around that by disabling HyperV which seemed to get further now fails that with lots of errors:
Can't create/start docker machine: Starting "default"...
(default) Check network to re-create if needed...
Error setting up host only network on machine start: C:\Program Files\Oracle\VirtualBox\VBoxManage.exe modifyvm default --nic2 hostonly --nictype2 82540EM --nicpromisc2 deny --hostonlyadapter2 VirtualBox Host-Only Ethernet Adapter #3 --cableconnected2 on failed:
VBoxManage.exe: error: Code E_FAIL (0x80004005) - Unspecified error (extended info not available)
VBoxManage.exe: error: Context: "LockMachine(a->session, LockType_Write)" at line 507 of file VBoxManageModifyVM.cpp
finished with error 1
I have also tried installing on Ubuntu, the file downloaded does not match the one described in your documents it is not called iss-iot-linux.tar.bz2 and ss-iot-launcher.sh  does not exist when it is extracted. On manually running install_GUI.sh or install.sh it fails with:
Failed to download file http://downloadmirror.intel.com/26206/eng/intel_iot_ostro.tar ;
Ideally I want to install this on my Mac is there any work around ? Thanks in advance.
Anonymous
Not applicable
Solved on the MAC at least, here is the correct documentation:
https://software.intel.com/en-us/node/660276
Anonymous
Not applicable
