Intel® System Studio
Ask questions and share information with other users of the Intel® System Studio.
Intel® System Studio components are now transitioned to several Intel® oneAPI toolkits and can be found under Intel oneAPI Base Toolkit and Intel oneAPI IoT Toolkit. Use the respective forums for questions related to these components. Getting Started questions can be asked in the Registration, Download, Licensing and Installation forum. If you have Priority Support you can submit your question in the Online Service Center.
346 Discussions
Cannot start Windbg Extension, Windows SDK issue.
Henshaw__Lee
I am having issues running the Windbg Extension for Intel System Studio debugger 2020. I get the message: "Installed MS SDK 18362 is currently not supported. Please install SDK <= 17134".
The problem is I DO have some Win10 SDKs less than 17134 version.
Things I tried that don't work:
1. Uninstall all SDKs > 17134.
2. Uninstalll 17134 SDK and reinstall it.
My guess is that even after uninstalling versions greater than 17134, there are registry key artifacts left behind that are triggering the tool to think it is installed. This shouldn't be an issue though anyway because based on the documentation, as long as I have ANY SDK less than or equal to 17134 it should work. I'm thinking of combing through registry and looking for artifacts, but the SDK install is very noisy. Maybe Ill run ProcMon and see what keys are being opened.
Any ideas? Also, can we get a reason and/or ETA for the new SDKs working? Thanks.
Henshaw__Lee
Okay it looks like even though I uninstalled the newer SDKs, the Windbg version 18362 persists. In ProcMon, I found that the extension is checking the version by literally creating the kd.exe process with the "-version" argument. I guess it then parses that output to determine. Now I just need to find a way to remove this newer windbg version and use an older one....or I might just use a different computer so I don't have to rewind my main one.
Cobler__Justin
This resource would help you a bit:
https://software.intel.com/en-us/articles/isd-windbg-extension
Regards.
Henshaw__Lee
Actually no, it does not address my specific question.
