Community
cancel
Showing results for
Search instead for
Did you mean:
Shah__Arpit
Cannot use socwatch after installation to measure power usage
Jump to solution
I've following the instructions and made sure all the kernel flags were enabled when the kernel was built. Also made sure to install the drivers per the instructions.
When I run socwatch with the following command:
sudo socwatch -t 60 -f cpu
I get these warnings:
WARNING: could not retrieve some architecture details -- your platform may not support collections
ERROR: CANNOT collect hw-cpu-pstate metric since zero frequency value was read from system. lfm = 0.00, hfm = 0.00, bus freq = 0.00
ERROR: Cannot collect feature: hw-cpu-cstate
Warning: feature name "hw-cpu-hwp" cannot be collected
ERROR: Unable to collect any metrics!
I have Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz with Ubuntu 16.04 on Kernel version 4.4.0
Joel_L_Intel
hi Arpit,
We have no problem to run -f hw-cpu-cstate. Can you help use ./socwatch  --version to confirm the latest version has been used? Meanwhile, our colleague can replicate this without loading socwatch2_x.ko . can you try "lsmod | grep -i socwatch" to check whether kernel module has been properly loaded or not and let us know.
Joel
Joel_L_Intel
hi Arpit,
Joel
