Community
cancel
Showing results for
Search instead for
Did you mean:
Craig_H_1
Compiled Application Size is Large
The size of my C++ compile using Intel System Studio Composer Edition is alarmingly large compared to the size of the compile using Visual Studio 2015 Community edition.
Intel compile size:   945 KB
VS 2015 compile size : 495 KB
Is this normal?
My application is rather heavy in floating point math.  I am compiling for a 14 core Intel E5-2697 v3 chipset to utilize the AVX2 and FMA3 instruction sets.
Pallavi_K_Intel
Below is the IPS issue that we are using to track the same issue.
IPS : https://employeeportal.intel.com/irj/servlet/prt/portal/prtroot/pcd!3aportal_content!2fintel_content...
Also sent you and e-mail on the below:
Could you send you the exact command line options that your using to run your code?
Also is it possible to share your code?
Do you see the same issue when you implement this with the smaller section of the code?
Pallavi
