Community
cancel
Showing results for
Search instead for
Did you mean:
Russell_B_1
Compiler Optimization level
I am running Microcontroller Studio with Quark SE C1000
How do I change the Optimization level of the Compiler?
At this point it is extremely nonexistent.
ebx  = ndata                      register uint32_t ndata;
 if((ndata & 0x20) == 0)                   // test data bit
40030184:   mov     %ebx,%eax
40030186:   and     $0x20,%eax
40030189:   test    %eax,%eax
4003018b:   jne     0x400301b7 <main+365>
and     $0x20,%eax     The OF and CF flags are cleared; the SF, ZF, and PF flags are set according to the result. The state of the AF flag is undefined.
test    %eax,%eax             is unnecessary it does the same thing and AND without changing the destination
The following code does the same thing
test    $0x20,%ebx
It runs 2.6 times faster.
Richard_A_Intel
Russell,
By default the tools build the project in debug mode to provide the user with detailed debug information.  If you want to build your project with optimizations turned on this you can select in from the drop down menu by the hammer icon as shown here:
Debug and Release Menu
This will disable your debug information in the build and turn on a set of preconfigured optimizations.  If you would like to customize what those settings are then you can do so from the projects Makefile as I described in this FAQ: https://software.intel.com/en-us/intel-system-studio-microcontrollers-support/faq#compiler-settings
Thank you,
Richard
John_D_Intel
Hey Richard, a related question: for a Zephyr project:  If I want to disable optimization for debugging, even if I select the Build Debug in the hammer it doesn't do it.    Then if I add this zephyr configuration option to the prj.conf the project gets halted in kernel files.   CONFIG_COMPILER_OPT="-O0"           #disable optimization causes project to halt
John
