Community
cancel
Showing results for
Search instead for
Did you mean:
mo_bri
D2000 Build Error for helloworld - on eclipse qm_adc.o no such file
I've been trying for a while now, and still can not create a simple project and build in.
I am running eclipse IDE and the official tools from the intel site. My OS is windows 10, and I suspect its a permissions error from the OS. I have tried changing all the folders in the workspace to have full permissions for all users.
I create a sample project based on hello world and click build....
02:15:37 **** Incremental Build of configuration build_debug for project dave ****
make
APP_NAME = dave
SOC = quark_d2000
APP_DIR = .
BUILD = debug
make -C ./bsp/drivers SOC=quark_d2000
BUILD = debug
make[1]: Entering directory `C:/Users/Owner/QuarkWorkSpace/dave/bsp/drivers'
i586-intel-elfiamcu-gcc -O0 -g -DDEBUG -std=c90 -Wall -Wextra -Werror -Wno-unused-parameter -fmessage-length=0 -I../include -fno-asynchronous-unwind-tables -I../drivers -I../drivers/include -march=lakemont -mtune=lakemont -miamcu -msoft-float -DSPI_IRQ_MST -I../soc/quark_d2000/include -c -o ../drivers/debug/quark_d2000/obj/qm_adc.o ../drivers/qm_adc.c
Assembler messages:
Fatal error: can't create ../drivers/debug/quark_d2000/obj/qm_adc.o: No such file or directory
make[1]: *** [../drivers/debug/quark_d2000/obj/qm_adc.o] Error 1
make[1]: Leaving directory `C:/Users/Owner/QuarkWorkSpace/dave/bsp/drivers'
make: *** [libqmsi] Error 2
02:15:38 Build Finished (took 651ms)
mo_bri
Seeing as there is no-one here, I thought I'd write a reply.As I expected its a combination of things, but mainly permissions to create folder, here is what I did to get it working.
First the java version error when running the IDE. Delete all those lines from the .bat script that check the java version (make sure you do have a 64 bit version though!)
Change the .bat to this
@ECHO off
GOTO endlegalheader
# Copyright (c) 2015 Intel Corporation
# All rights reserved. This program and the accompanying materials
# are made available under the terms of the Eclipse Public License v1.0
# which accompanies this distribution, and is available at
# http://www.eclipse.org/legal/epl-v10.html
:endlegalheader
IF EXIST issm_env.bat (
    ECHO Running my version of the starter.
    CALL issm_env.bat
) ELSE (
    ECHO ERROR: Unable to setup the environment
    ECHO Please execute the issm_env.bat located at the ISSM install directory, and restart Eclipse
    PAUSE
    GOTO end
REM Environment variables
SET ISSM_QMSI_ROOT_DIR=%ISSM_ROOT%\firmware\bsp\1.0
SET ISSM_QMSI_EXAMPLES_DIR=%ISSM_QMSI_ROOT_DIR%\examples
SET ISSM_OPENOCD_DIR=%ISSM_ROOT%\tools\debugger\openocd
SET ISSM_GDB_DEFAULT_BIN=%ISSM_ROOT%\tools\debugger\gdb\gdb-ia.exe
SET PATH=%PATH%;%ISSM_ROOT%\tools\compiler\bin
SET ERROR_FOUND=false
IF NOT EXIST %ISSM_QMSI_ROOT_DIR% (
    ECHO WARNING: Unable to find ISSM_QMSI_ROOT_DIR
    set ERROR_FOUND=true
IF NOT EXIST %ISSM_QMSI_EXAMPLES_DIR% (
    ECHO WARNING: Unable to find ISSM_QMSI_EXAMPLES_DIR
IF NOT EXIST %ISSM_OPENOCD_DIR% (
    ECHO WARNING: Unable to find ISSM_OPENOCD_DIR
IF NOT EXIST %ISSM_GDB_DEFAULT_BIN% (
    ECHO WARNING: Unable to find ISSM_GDB_DEFAULT_BIN
IF "%ERROR_FOUND%" EQU "true" (
    ECHO WARNING: Please check your configuration and restart Eclipse
    PAUSE
START %ISSM_ROOT%\eclipse\eclipse.exe -vm C:\Java\JREs\64Bit\bin\javaw
:end
I have just deleted the java checking (which doesnt work), and forced eclipse to run with my 64 bit version. Problem 1 solved !
Then run the eclipse IDE (from the script), and create your project.
Now go to the project folder in your workspace, and create a .bat file and shove this in
mkdir bsp\build\release\quark_d2000\libqmsi\lib
mkdir bsp\drivers\release\quark_d2000\obj
mkdir bsp\sys\release\quark_d2000\obj
mkdir release\quark_d2000\obj
mkdir release\quark_d2000\bin
mkdir bsp\build\debug\quark_d2000\libqmsi\lib
mkdir bsp\drivers\debug\quark_d2000\obj
mkdir bsp\sys\debug\quark_d2000\obj
mkdir debug\quark_d2000\obj
mkdir debug\quark_d2000\bin
REM then add this line "CFLAGS += -I$(BASE_DIR)/drivers/include" to the base.mk file inside
REM the bsp folder
This will create the folders you need when you run it. So run it ! - PROBLEM 2 solved
Follow the instructions in the remark statements at the end, so
edit the base.mk file in the top level bsp folder (INSIDE your workspace project folder), and add this line with the CPFLAGS, basically there is a missing include folder in the make file, and this puts it in (-I means include folder/path) - PROBLEM 3 solved
Richard_A_Intel
Marcus,
Thank you for reporting these issues and I'm glad you were able to find a workaround for them.  We are working on a fix to the problems you noted and hope to resolve soon.  Other users have found they were able to overcome the issues but removing third party make utils from the path while running ISSM also worked.
Thank you,
Richard
guillermo_a_1
I'm still having problems with this. I've done all of the steps, but I'm not sure about which name should I took for the .bat that marcus recommend to create with the following code:
I'd be glad if anyone could explain this part better.
Thanks!
Guillermo
guillermo_a_1
11:37:32 **** Incremental Build of configuration build_debug for project Blink_LED ****
make
APP_NAME = Blink_LED
SOC = quark_d2000
APP_DIR = .
BUILD = debug
BUILD = debug
make[1]: Entering directory `C:/IntelSWTools/ISSM_2016.0.027/workspace/Blink_LED/bsp/drivers'
make[1]: Leaving directory `C:/IntelSWTools/ISSM_2016.0.027/workspace/Blink_LED/bsp/drivers'
i586-intel-elfiamcu-gcc -DPRINTF_ENABLE -DPUTS_ENABLE -O0 -g -DDEBUG -std=c90 -Wall -Wextra -Werror -Wno-unused-parameter -fmessage-length=0 -I./bsp/include -fno-asynchronous-unwind-tables -I./bsp/build/debug/quark_d2000/libqmsi/include -march=lakemont -mtune=lakemont -miamcu -msoft-float -DSPI_IRQ_MST -I./bsp/soc/quark_d2000/include -I./bsp/board/drivers -c -o debug/quark_d2000/obj/main.o main.c
In file included from ./bsp/soc/quark_d2000/include/qm_soc_regs.h:33:0,
                 from main.c:1:
./bsp/include/qm_common.h:40:19: fatal error: qm_rc.h: No such file or directory
compilation terminated.
make: *** [debug/quark_d2000/obj/main.o] Error 1
guillermo_a_1
Ok,
It seems I manage to solve the problem, I was adding "CFLAGS += -I$(BASE_DIR)/drivers/include" in base.mk but under ##Variables instead of ##FLAGS.
