Intel® System Studio
Ask questions and share information with other users of the Intel® System Studio.
Intel® System Studio components are now transitioned to several Intel® oneAPI toolkits and can be found under Intel oneAPI Base Toolkit and Intel oneAPI IoT Toolkit. Use the respective forums for questions related to these components. Getting Started questions can be asked in the Registration, Download, Licensing and Installation forum. If you have Priority Support you can submit your question in the Online Service Center.
346 Discussions
ERROR E-2201: The DAL interface library was loaded but the call to AllocIUmanaged failed
DM_M_
Hello!
I've got an error in Intel JTAG Debugger 2014 when trying to connect to ITP-XDP3 - ERROR E-2201: The DAL interface library was loaded but the call to AllocIUmanaged failed.
How can I solve this problem?
Thanks in advance!
Robert_M_Intel1
Dear DM,
this error message indicates that a call to a debugger backend (Dfx Abstraction Layer) allocation function failed.
Can you let me know which exact target processor you are trying to connect to an which connection setting you are using in the debugger started via start_xdb_2014_products.sh/start_xdb_2014_products.bat?
Before moving on to my next recommendation below. I would like to check on a simple connection attempt using slightly incorrect connection settings first.
In the next step we could then check if we are dealing a faulty backend installation or USB driver installation.
If you are using it on Windows host, could you check if trying a different USB port works? Else,  I would recommend an uninstall and re-install oft he Intel(R) DFx Abstraction Layer  (Intel(R) DAL). The easiest way to do this is probably to go into the control panel to uninstall it and then use the Intel Systen Studio installer to d o a resinstallation.
If you are using ito on a Linux host you may want to double chck the prerequisites like the Mono package.
Thanks, Rob
Robert_M_Intel1
DM,
sorry one more question: Can you let me know if you have any other Intel debug tools or analysis software tools (other than those coming with Intel System Studio) installed in parallel to the Intel(R) JTAG Debugger?
Thanks, Rob
