Community
cancel
Showing results for
Search instead for
Did you mean:
Sebastian_B_
Eclipse Build Ouptut Parser
it seems that Eclipse is giving the wrong information about what defines are set.
Steps to reproduce:
Open the Hello World example with ISSM.
Open the zephyr/include/misc/printk.h file and you will find this code:
#ifdef CONFIG_PRINTK
extern void printk(const char *fmt, ...);
#else
static inline void printk(const char *fmt, ...)
    ARG_UNUSED(fmt);
#endif
Expected results:
Eclipse should darken the background colour of the lines
    ARG_UNUSED(fmt);
to indicate that this code has been ifdef'd out.
Actual result:
This code is darkened instead:
Opening autoconf.h shows that CONFIG_PRINTK is defined, so Eclipse is giving the wrong indication
about the source code.
Why is Eclipse doing this and how can I fix this?
Alice_H_Intel
The darken area only related to the #ifdef or #ifndef that the function you used. For the '#ifdef' function, eclipse will darken the first expression. Otherwise, the 'else' condition will be darken when the ''#ifndef is used.
Hope this can reply your question.
Alice
