Dear All,
I am trying to install:
Intel System Studio IoT Edition
Version: 2016.0.004
This is on:
MacBook Air (Bootcamp dual boot)
Windows 8.1 Enterprise
8 GB RAM
I have previously installed:
Oracle VM VirtualBox 5.1.8 r111374 (Qt5.5.1)
7z1604-x64.exe
jdk-8u111-windows-x64.exe (Java version 8 Update 111)
DockerToolbox-1.12.3.exe
However, during the installation of w_iss_iot_2016.0.004.exe I get:
Intel® System Studio IoT Edition Setup Wizard ended prematurely because of an error(s).
Can't load image: An error occurred trying to connect: Post http://%2F%2F.%2Fpipe%2Fdocker_engine/v1.24/images/load?quiet=1: open //./pipe/docker_engine: The system cannot find the file specified. finished with error 1
To install this program at a later time, run Setup Wizard again. Click the Finish button to exit the Setup Wizard.
I previously had some issues with VirtualBox adaptors and a machine restart seems to have fixed that.
Any help much appreciated.
Ben
Looks to be related to this:
http://stackoverflow.com/questions/37527888/docker-commands-fails-in-windows
When I open the Docker Quickstart Terminal I get:
Starting "default"...
(default) Check network to re-create if needed...
Error setting up host only network on machine start: C:\Program Files\Oracle\Vir
tualBox\VBoxManage.exe modifyvm default --nic2 hostonly --nictype2 82540EM --nic
promisc2 deny --hostonlyadapter2 VirtualBox Host-Only Ethernet Adapter #2 --cabl
econnected2 on failed:
VBoxManage.exe: error: Code E_FAIL (0x80004005) - Unspecified error (extended in
fo not available)
VBoxManage.exe: error: Context: "LockMachine(a->session, LockType_Write)" at lin
e 507 of file VBoxManageModifyVM.cpp
Looks like something went wrong in step ´Checking status on default´... Press an
y key to continue...
If I load VBox, and try to run the default VM I also get:
The VM session was aborted.
Result Code: |
E_FAIL (0x80004005) |
Component: |
SessionMachine |
Interface: |
ISession {7844aa05-b02e-4cdd-a04f-ade4a762e6b7} |
I not have HyperV installed. I do have VMWare.
