Hi Intel tutors in Intel® System Studio,
I think I have already installed SDK 2017 and oracle-java-8 and libicu52.
But the error I encountered that error. It seems that my java is not correct. But I don't know where it is. I don't know where the log of code builder.
If you had also encountered that. Help me out please, Thanks a lot...
shan@shan-ZHAOYANG-E51-80:/etc/alternatives$ java -version
java version "1.8.0_191"
Java(TM) SE Runtime Environment (build 1.8.0_191-b12)
Java HotSpot(TM) 64-Bit Server VM (build 25.191-b12, mixed mode)
shan@shan-ZHAOYANG-E51-80:/etc/alternatives$ javac -version
javac 1.8.0_191
shan@shan-ZHAOYANG-E51-80:/tmp/iss_env_shan_20181123130527$ cat eclipse.log
2018-11-23 13:06:01 ERROR - com.intel.iss.core.sample.SampleProvider.java:747 (isReachable) - Could not connect to URL http://iotdk.intel.com/samples-iss/iss2019-gold/c.json: connect timed out
2018-11-23 13:10:22 ERROR - com.intel.iss.core.sample.SampleProvider.java:747 (isReachable) - Could not connect to URL http://iotdk.intel.com/samples-iss/iss2019-gold/c.json: connect timed out
2018-11-23 13:10:23 ERROR - com.intel.iss.core.sample.SampleProvider.java:747 (isReachable) - Could not connect to URL http://iotdk.intel.com/samples-iss/iss2019-gold/cpp.json: connect timed out
2018-11-23 13:10:24 ERROR - com.intel.iss.core.sample.SampleProvider.java:747 (isReachable) - Could not connect to URL http://iotdk.intel.com/samples-iss/iss2019-gold/java.json: connect timed out
================================================================================ Sourcing /opt/intel/system_studio_2019/debugger_2019/bin/debuggervars.sh Sourcing /opt/intel/system_studio_2019/env.d/linux/70-gdb-env.sh Sourcing /opt/intel/system_studio_2019/env.d/linux/70-iot_ide.sh ERROR - Please install docker and ensure it is in the environment PATH Sourcing /opt/intel/system_studio_2019/env.d/linux/70-openipc-env.sh Sourcing /opt/intel/system_studio_2019/env.d/linux/70-tca-env.sh Sourcing /opt/intel/system_studio_2019/env.d/linux/70-trace-env.sh Sourcing /opt/intel/system_studio_2019/env.d/linux/70-wrl-env.sh ================================================================================ Environment variables LC_PAPER=zh_CN.UTF-8 XDG_VTNR=7 MANPATH=/opt/intel/system_studio_2019/documentation_2019/en/debugger/gdb-ia/man/:/usr/local/man:/usr/local/share/man:/usr/share/man:/usr/lib/jvm/java-8-oracle/man LC_ADDRESS=zh_CN.UTF-8 XDG_SESSION_ID=c4 CLUTTER_IM_MODULE=xim XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/shan LC_MONETARY=zh_CN.UTF-8 GIO_LAUNCHED_DESKTOP_FILE_PID=8765 SESSION=ubuntu LIBVA_DRIVERS_PATH=/opt/intel/mediasdk/lib64 INTEL_LICENSE_FILE=/opt/intel/system_studio_2019/licenses:/opt/intel/licenses:/home/shan/intel/licenses:/Users/Shared/Library/Application Support/Intel/Licenses GPG_AGENT_INFO=/home/shan/.gnupg/S.gpg-agent:0:1 ECLIPSE_DBG_SETTINGS_FILE=/opt/intel/system_studio_2019/settings.properties XDG_MENU_PREFIX=gnome- SHELL=/bin/bash NPK_ROOT=/opt/intel/system_studio_2019/system_debugger_2019/system_trace DERBY_HOME=/usr/lib/jvm/java-8-oracle/db DOCKER_HOST=unix:///var/run/docker.sock INSTALL_DIR=/opt/intel/system_studio_2019 QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1 LC_NUMERIC=zh_CN.UTF-8 LIBVA_DRIVER_NAME=iHD UPSTART_SESSION=unix:abstract=/com/ubuntu/upstart-session/1000/7957 GNOME_KEYRING_CONTROL= GTK_MODULES=gail:atk-bridge: WIND_LINUX_CONFIGURE=/opt/intel/system_studio_2019/WindRiver/wrlinux-x/scripts/project-configure.sh NO_PROXY=127.0.0.1 USER=shan LD_LIBRARY_PATH=/opt/intel/system_studio_2019/debugger_2019/libipt/intel64/lib QT_ACCESSIBILITY=1 LC_TELEPHONE=zh_CN.UTF-8 INTELOPENCLSDK=/opt/intel/opencl/SDK XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session1 XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0 SSH_AUTH_SOCK=/run/user/1000/keyring/ssh ISS_OPENIPCBINDIR=/opt/intel/system_studio_2019/system_debugger_2019/debugger/openipc/Bin SESSION_MANAGER=local/shan-ZHAOYANG-E51-80:@/tmp/.ICE-unix/8363,unix/shan-ZHAOYANG-E51-80:/tmp/.ICE-unix/8363 DEFAULTS_PATH=/usr/share/gconf/ubuntu.default.path ISS_ROOT=/opt/intel/system_studio_2019 GIO_LAUNCHED_DESKTOP_FILE=/home/shan/Desktop/Intel(R) System Studio.desktop XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/usr/share/upstart/xdg:/etc/xdg NLSPATH=/opt/intel/system_studio_2019/debugger_2019/gdb/intel64/share/locale/%l_%t/%N PATH=/opt/intel/system_studio_2019/system_debugger_2019/system_trace/bin:/opt/intel/system_studio_2019/debugger_2019/gdb/intel64/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/lib/jvm/java-8-oracle/bin:/usr/lib/jvm/java-8-oracle/db/bin:/usr/lib/jvm/java-8-oracle/jre/bin DESKTOP_SESSION=ubuntu ISS_TOOLS_ROOT=/opt/intel/system_studio_2019/tools TEMPDIR=/tmp/iss_env_shan_20181123130527 QT_IM_MODULE=fcitx QT_QPA_PLATFORMTHEME=appmenu-qt5 WIND_HOME=/opt/intel/system_studio_2019/WindRiver TCA_INSTALL_DIR=/opt/intel/system_studio_2019/system_debugger_2019/tca LC_IDENTIFICATION=zh_CN.UTF-8 JOB=dbus PWD=/opt/intel/system_studio_2019 XDG_SESSION_TYPE=x11 JAVA_HOME=/usr/lib/jvm/java-8-oracle XMODIFIERS=@im=fcitx LANG=en_US.UTF-8 GNOME_KEYRING_PID= GDM_LANG=en_US MANDATORY_PATH=/usr/share/gconf/ubuntu.mandatory.path LC_MEASUREMENT=zh_CN.UTF-8 MFX_HOME=/opt/intel/mediasdk IM_CONFIG_PHASE=1 COMPIZ_CONFIG_PROFILE=ubuntu PAPERSIZE=a4 ITH_PYTHON_DIR= ISS_TCA=1 GDMSESSION=ubuntu INTEL_PYTHONHOME=/opt/intel/system_studio_2019/debugger_2019/python/intel64/ LOGFILE=/tmp/iss_env_shan_20181123130527/iss_env.log GTK2_MODULES=overlay-scrollbar SESSIONTYPE=gnome-session HOME=/home/shan SHLVL=1 XDG_SEAT=seat0 LANGUAGE=en_US:en ISS_ENV_DIR=/opt/intel/system_studio_2019/env.d/linux GNOME_DESKTOP_SESSION_ID=this-is-deprecated XDG_SESSION_DESKTOP=ubuntu LOGNAME=shan XDG_DATA_DIRS=/usr/share/ubuntu:/usr/share/gnome:/usr/local/share:/usr/share:/var/lib/snapd/desktop:/var/lib/snapd/desktop DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-KW5PwbdzWR QT4_IM_MODULE=fcitx J2SDKDIR=/usr/lib/jvm/java-8-oracle INFOPATH=/opt/intel/system_studio_2019/documentation_2019/en/debugger/gdb-ia/info/ INSTANCE= DISPLAY=:0 XDG_RUNTIME_DIR=/run/user/1000 XDG_CURRENT_DESKTOP=Unity GTK_IM_MODULE=fcitx J2REDIR=/usr/lib/jvm/java-8-oracle/jre LC_TIME=zh_CN.UTF-8 LC_NAME=zh_CN.UTF-8 XAUTHORITY=/home/shan/.Xauthority _=/usr/bin/env ================================================================================
Hello Shan,
This looks like a networking issue to me.
Can you please check that your computer can access the Internet?
In case your network requires a proxy server to access the Internet, please configure it in the Window -> Preferences -> General -> Network Connections menu.
Sergey
