Community
cancel
Showing results for
Search instead for
Did you mean:
Homam_Dabis
How big is the linux kernel and file system
I have a general question regarding size of software.
Our embedded system would have 512M of flash and no hard disk. We would want to run our app (not big) and a browser.
Is this possible or do we need more flash memory? I know that meego is over 800M in size but can that be customised so that unwanted applications are not included.
Homam
Robert_M_Intel1
Hi Homam,
the size of the Linux kernel really depends on the feature set you require.A standard kernel tens to be close to 1Gb, but below 100Mb are not unheard of. If you remove unwanted services and everything you don't need what you have in mindshould be doable.
There is a project called Yocto. I would like to recommend to go to yoctoproject.org and submit your question about what are the most effective size reduction approaches if you still need a GUI and web interface, but not much elseto their mailing list. Yocto Project is an embedded Linux* framework focused on enabling customizing Linux to embedded needs. They may be able to provide some good tips and tricks. It is not MeeGo*, but it is more flexible than MeeGo for what you have in mind. A lot of the feedback from them should be also applicable to be valid for MeeGo should you decide to stay with it.
Thanks, Rob
