Community
cancel
Showing results for
Search instead for
Did you mean:
CLu1
How to enable IPP library on C1000 sensor subsystem core
Hi
From the example "Accelerometer", It mentions that can optionally make use of the IPP library to print statistical data.
But how to config the makefile to enable IPP library.
Richard_A_Intel
Thank you for your question.  Currently IPP is only supported for X86 architecture which allows it to run on the Quark core on the C1000.  The note that it can optionally run with IPP enabled is for if you choose to run the accelerometer sample from the Quark Core, it is not supported on the Sensor Subsystem at this time.  If you have an use case where it would be helpful to enable it for the Sensor Subsystem then let us know the details and we can take that under consideration.
Thank you,
Richard
