Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Intel CE4100 SDK building
I am following the steps given in Intel CE Media processors document.
After installation of ISOs, i am using make menuconfig to build the SDK.
In that menu Kernel selection menu item is there, which i selected as none. There are two other options available in the selection menu. what is the significance of this?
When i selected linux as my kernel i am unable to build my SDK successfully. So i selected none.
I tried to build an example application generated with above SDK build tool chain(Kernel as NONE).
Can i assume that my executable runs on actual hardware ?
Thanks in Advance
BrandIntel
Dear BrandIntel,
the SDK that you are referring to is not a public Intel product and not part of the Intel Embedded Software Development Tool Suite. If you obtained your development platform from Videon, please contact Videon-Central for support. They should be able to assist you.
Otherwise,please contact your Intel contact directly or reply with a private post providing your email address to continue this discussion.
Thanks,Rob
