Community
cancel
Showing results for
Search instead for
Did you mean:
Harsh_R_Intel
Intel System Studio facing issues in Fedora 23
Hi All,
I have installed Intel System Studio on Fedora 23. The installation seems to be fine. When I am trying to start the system debugger using start_xdb_gdb_remote.sh script, It flashes the start screen of Intel System Debugger once and then does not do anything. "ps" is not showing any processes running for system debugger. Installation of the same ISS works fine in another Fedora 23 machine.
Does anyone have any idea about what might be the issue?
Harsh.
Hubert_H_Intel
Harsh,
I'll check what the problem could be.
Regards, Hubert.
Hubert_H_Intel
Harsh,
start_xdb_gdb_remote.sh requires a Java Runtime Environment 64-bit version 1.6 or later.
What does
   java -version
show when it's invoked from the command prompt where you started the debugger script?
Regards, Hubert.
Harsh_R_Intel
Hubert,
You are right. The issue was the java version. I have installed the latest one and it is working now. Thanks for replying.
- Harsh.
