Community
cancel
Showing results for
Search instead for
Did you mean:
Rohit_S_1
Intel i7 based SBC with Clock Sync to a DSP unit
I want to achieve visual IMU synchronization, for which I require to drive a DSP (Atmel SAM21 series MCU) with the clock of the i7 in order to have the IMU and visual data from the cameras connected to the i7 and the sensor data coming from the DSP are processed in the same clock and is correctly patched together without error.
Please suggest any Intel i7 based SBC with a clock sync pin out or similar facility.
