Intel® System Studio
Ask questions and share information with other users of the Intel® System Studio.
Intel® System Studio components are now transitioned to several Intel® oneAPI toolkits and can be found under Intel oneAPI Base Toolkit and Intel oneAPI IoT Toolkit. Use the respective forums for questions related to these components. Getting Started questions can be asked in the Registration, Download, Licensing and Installation forum. If you have Priority Support you can submit your question in the Online Service Center.
Kconfig problem in ISSM
matthew_h_5
I have a problem with my Kconfig file in ISSM. If I modify it at all, the project won't build any more. I'm trying to add drivers to the project but when I modify the prj.conf file, I get errors. I only try to add one line to the Kconfig file at the top under the driver configuration options. Any suggestion? This seems to break the project forever. I can't come back from it.
10:54:58 **** Incremental Build of configuration Debug for project GPIO ****
"C:\\MinGW\\msys\\1.0\\bin\\bash.exe" --login -i -c "cd C:/IntelSWTools/ISSM_2016.1.067/workspace/GPIO && make"
Using c:/IntelSWTools/ISSM_2016.1.067/workspace/GPIO/zephyr/boards/quark_d2000_crb/quark_d2000_crb_defconfig as base
Merging c:/IntelSWTools/ISSM_2016.1.067/workspace/GPIO/zephyr/kernel/configs/nano.config
Merging prj.conf
sed: preserving permissions for `./sed014300': Permission denied
sed: preserving permissions for `./sed018572': Permission denied
c:\IntelSWTools\ISSM_2016.1.067\workspace\GPIO\zephyr\boards\Kconfig:2:warning: config symbol defined without type
*** Error during writing of the configuration.
make[3]: *** [oldnoconfig] Error 1
make[2]: *** [oldnoconfig] Error 2
make[1]: *** [sub-make] Error 2
make: *** [/c/IntelSWTools/ISSM_2016.1.067/workspace/GPIO/outdir/.config] Error 2
10:55:03 Build Finished (took 5s.894ms)
Alice_H_Intel
Hi Matthew,
Can you try to delete outdir folder and rebuild it again ? It works for me. Looks like it have some problem if you didn't start with a clear build.
please let me know how it works for you.
Alice
Alice_H_Intel
Hi Mattew,
Thanks for your question. May I know what's the instruction you tried to add/modify to prj.conf and Kconfig ? Have you successfully built the Zephyr project without any modification ?
Alice
matthew_h_5
The project builds fine without modification. It doesn't matter what modification I make to the prj.conf file. Adding any line to it causes this problem. Deleting the change and reverting back to the original, the problem remains. Something about modifying the prj.conf file in any way causes this error.
matthew_h_5
It appears to be a problem with "merging prj.conf". The project builds fine from the command line in Linux.
Alice_H_Intel
Hi Matthew,
Alice
matthew_h_5
Yes. That resolves the problem. Will this be corrected in the next version of ISSM?
Alice_H_Intel
Hi Matthew,
It's great to hear issue solved. I will feedback this issue to the team to see how we can improve it in the future release.
Alice
